Is there a certain type of cams I need to use if I plan on using nitrous eventually? I was thinking of getting either vt stage 1 or 2 cams and then installing nitrous. Wasn't sure if I needed a certain type of cam like you need for a blower.
I'm pretty sure you just use N/A cams, so vt stage 1's or 2's should be fine, but you don't NEED to change your cams to use nitrous. I don't know what type of nitrous you're planning, but I wouldn't go the cheap route if I were you. I'd rather spend a bunch of money on the NX plate kit and keep stock cams than go with a cheap nitrous kit just so I could buy cams too. Ofcourse, if you can afford the plate kit AND cams......
