Nitrous Questions
  • Thread starter Thread starter Checkmate
  • Start date Start date Apr 14, 2007
C
Checkmate
  • Apr 14, 2007
I have a 1991 GT convertible with a Lentech AOD and some bolt ons (AFR 185's, intake, cam etc.) and want to add a 150 shot or so of nitrous. I have talked to some local shops and they have both told me that this may be to much for a Fox body comvertible to handle without twisting the car. Does anyone on here have a nitrous kit in a convertible without a cage? How big a shot are you running? The car leaves the line very soft with the AOD and I don't think that a 150 shot of nitrous would be that hard on it, what are your opinions? Also any pics of installs on convertibles would be great!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 14, 2007
  • Apr 14, 2007
Well you would leave much harder with a nitrous shot specially a 150 hp shot. The verts are more twisty then the rest of the mustangs. I would recomend installins a good set of sub frame connectors before using the juice. This will stiffen up the car alot.
C
Checkmate
  • Apr 14, 2007
I have a custom welded set in the car right now, anything else?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 14, 2007
  • Apr 14, 2007
I would go play then. There are lots of vert out there without roll cages playing at the strip. If you have improved the chassis by adding a subframe connector go play.
RYC CUKR
1,437
Orlando
Apr 14, 2007
  • Apr 14, 2007
I run a 100 wet shot on my 93 with full length MM sub frames. I haven't ever noticed any ill effects from excessive twist. That said I don't leave on the nitrous I have a window switch that brings in on at 3k and shuts it off at 6k. The car went from 14.0s to 12.7s with just the 100 shot. This is with the stock converter.
C
Checkmate
  • Apr 17, 2007
Thanks for the reply, your car sounds a lot like mine. Are you happy with the Trickflow kit? I am concidering this kit myself. Is the nitrous on while the car shifts? Do you have a custom tune in the car? Any feedback and pics of your setup would be great!
First gear is too tall. Should I make it taller? Nitrous guys, help!
  • FastDriver
  • Dec 30, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 31, 2023
AeroCoupe
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
E
For Sale 1991 Ford Mustang GT Convertible for sale
  • ejregenfuss
  • Oct 1, 2023
4K
Fox Body Mustangs For Sale (1979-93) Oct 1, 2023
ejregenfuss
E
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
