You will also want some electronics that will help you operate your nitrous safely. A WOT switch, which is included in most complete kits, and an rpm window switch are must haves.
Most bolt-ons except pulleys, 4.10 gears, 31 spline axles/diff, et street radials for the track, steeda adjustable lca's, mm full-length sfc's, 125 shot nozzle kit from Harris Speed Works.
hey tim. same here mostly bolts ons except 4 pullyes 2,mac long tubes,dr gas x-pipe,tubular frt with adj coil overs lakewood 50/50 rear shocks upr upper n lower c/a 355 aub with trac lock moser axle and t-45 rebuilt by bangin bob halon.
