No 5th or reverse in T5...
  • Thread starter Thread starter 95GTAODE
  • Start date Start date Jul 31, 2006
9
95GTAODE
200
  • Jul 31, 2006
Just like it says. I replaced the tail stock on my 4cyl T5 tranny with one from a V8 T5, and now I cannot get it to go into 5th or reverse, but 1-4 are smooth as butter. It won't even grind, they just won't go.
Any idea's? I really don't want to pull the tranny. (again)
Sicarius428
2,085
Jul 31, 2006
  • Jul 31, 2006
Does the shifter actually go or pretend to go into 5th or R? Both 5th and R are on the same linkage so I am curious if thats the issue.
Kevin
9
95GTAODE
200
  • Jul 31, 2006
Nope. I can move it over, but as soon as I try and go up to 5th, or down to reverse, it's like hitting a wall.
Killer50stang
632
  • Jul 31, 2006
These trannies work on V-8's but usually cause isses. As long as you changed out the piolet bearing, you should be okay. Did it work before? Time for a TKO?
9
95GTAODE
200
  • Jul 31, 2006
It worked great before. I have the proper pilot bearing as well. One of the mount bolts broke off in the pad, so I swapped on the tailshaft from my trashed V8 T5. I had it out for an engine swap, so it seemed to be the easiest way to solve that problem.
larrendeuce
649
Southern NJ
Jul 31, 2006
  • Jul 31, 2006
This happened to me when I went to put my t5 back together. In my case the 5-R shift rail was bent and when I put the case back on it wasn't aligned properly. I got a spare shot t5 from a friend and replaced the shift rail. I also wasn't too kind on the 5-R shift lever and snapped off the fork at the top.
After replacing those parts it went into reverse fine. I'd say take it back apart (save the fluid) and see whats causing the problem.
Killer50stang
632
  • Jul 31, 2006
larrendeuce said:
This happened to me when I went to put my t5 back together. In my case the 5-R shift rail was bend and when I put the case back on it wasn't aligned properly. I got a spare shot t5 from a friend and replaced the shift rail. I also wasn't too kind on the 5-R shift lever and snapped off the fork at the top.
Sounds like this is your only choice. Good luck!
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
