- Jun 7, 2010
- 2
- 0
- 0
Hello all,
I am having a problem on my 1993 mustang 5.0 conv (automatic)
I have no brake lights.
All the other lights work, just not the brake lights.
I don't know what else to do to get the brake lights to function
I have replaced the multi-function turn signal switch, the fuses are all good, all the brake light bulbs have been replaced, the brake switch or stop light switch on the brake peddle has been replaced. And the battery cables have been cleaned also.
And I am having trouble getting it from park into reverse. Under the shifter there is a white piece of plastic that has a loop in it. Someone said that is a safety feature on that year of car. I have been using a screwdriver to stick into the plastic loop and then I can shift the car out of park. I also have to step on the brake peddle at the same time. And the cruise control doesn't work either.... I think that is the clock spring. Air bag light is on also ... has been for about 2-3 years.... flashes three times then two OR two then three times
I am almost sure it is a ground problem with the brake lights.
Could someone give me a starting point as to where to
look or better yet a wiring diagram. Thanks
When I bought the car in 1996 there was no glove box manual for it... so I have found the missing items from other friends that have mustangs
Thanks in advance,
Whitemustanggirl
All the other lights work, just not the brake lights.I don't know what else to do to get the brake lights to function
Thanks in advance,
Whitemustanggirl
