NO Brakes!!
93lx
14
I just bought a 86 GT that has been sitting for about a year. The motor runs fine but the brakes don't work. The pedal goes all the way to the floor. You can pump them up and get a little pressure but not much. I have never worked on brakes much so what should I look for? There is plenty of brake fluid in the reservoir. Could the pistons in the calipers be locked up? Thanks!
check the back of the master cylinder see if theres any fluid leaking down the firewall or if any of the paint is bubbled or gone, check for leaks anywhere along the lines, see if the rubber hoses are weather cracked and if so replace them. Then I'd bleed and flush the system to remove any air or condensation that may have built up... if that fixes it your set. ;)
Ditto. If the MC internal seals go out, the fluid just passes around inside the MC, not out to the brakes. I've had 2 or 3 go out like that. You can pump them up, but they eventually drop to the floor again. But do check everything else, especially if it has been sitting. 20 year old brake lines might need to be replaced, and the fluid for sure needs to be bled.
