No heat WTF
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Nov 4, 2004
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 4, 2004
  • Nov 4, 2004
Well here in nepa it finally dropped below 40 degrees last night. I was coming home and turned the heat on and it was cold the whole time the engine temp was reading in the middle. The heater core isnt bad because there are no leaks of coolant any where on the car. Im stumped i dunno what it could be i was thinking maybe the thermostat was stuck open but there would still be heat right? I need this problem fixed quick being this is my daily driver and its getting cold.
BlackGT89
774
Huntsville, AL
Nov 4, 2004
  • Nov 4, 2004
If you still have your original heater core (like I do) there is a good chance that years of corrosion are severely restricting the water passage through the core. You can try a flush, but most of what is out there seems to be little more than rubbing alcohol they are so mild. I ran the Ford flush for a few days and it finally cleaned the corrosion out enough to get a little hot water through the core. Feel the water line coming into the core and then feel the water line coming out of the core. If the "in" line is hot and the "out" line is cold it's probably clogged up. If the "out" line is warm you probably have another problem like some of the blend doors not working properly.
Boss_Mustang_69
34
BC, Canada
Nov 4, 2004
  • Nov 4, 2004
Or an even simpler thing might be that you're low on fluid in you're rad? Just check it.
artus70
72
  • Nov 4, 2004
That was my problem heater core was fine, thermostat was fine but no real heat to speak of......
RsStanG1987
569
9
79
Dupont PA
Nov 4, 2004
  • Nov 4, 2004
Blend doors not sure of what they are. My radiator fluid is fine checked it hot and cold. Just cant under stand it. And if the water coming out is cold and the water in is hot wouldnt that give me heat or make the car overheat?
RsStanG1987
569
9
79
Dupont PA
Nov 5, 2004
  • Nov 5, 2004
anyone else
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Nov 5, 2004
  • Nov 5, 2004
same problem here....replaced a leaking heater core last year and everything is working properly. heat works if its above 45 or so...but anything below that and its just cold. not sure if its just because the coolant isnt hot enough because of the 180 tstat and the flow restrictors in the lines to heater core or what.....im stumped
bryanrevans
296
Chicopee,Mass
Nov 5, 2004
  • Nov 5, 2004
Hey man when you move the blue to red ie cool to warm you are opening ang closeing the damper door like on a furnace.Even with a 160 therm the coolant runnin through the core is hot enough after warm up.When you feel the tempt control knob feel for resistance if its to free then maybe the cable is bunched or not even connected??????My fan and controls werent even in the car and I could feel heat in the vent.Doing a interior swap.Hope this ponts you somewhere wew!!!!!poor typer man!!!!!
D
Demented4.6
1,055
DAYTON, OHIO
Nov 5, 2004
  • Nov 5, 2004
id try a fluch like said above.. probably clogged up
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
M
Engine Throttle sticking
  • Magnet86
  • Feb 5, 2025
Fox 5.0 Mustang Tech Apr 1, 2025
General karthief
