I am having problems getting power to my fuel pump. The trouble started when I replaced my battery(trunk mounted) and figured I didn't need to bolt it back in, because I was only driving around the block. I took a corner too fast and the battery came unplugged. After that the fuel pump wouldn't kick on. I am not sure what kind of problem that would cause. I replaced the wire running to it as well as the relay. I hooked it up to make sure the pump wasn't bad, and it isn't. Everything else electrical seems to be working fine. I am kind of at a loss, any help would be appreciated.
