NO OIL PRESSURE! EEK!
  • Thread starter Thread starter fox racer
  • Start date Start date Jan 5, 2006
fox racer
577
Staten Island, NYC
Jan 5, 2006
  • Jan 5, 2006
Ok, I though my O/P gauge was just broken or misreading, so I decided to install an autometer (Phantom) gauge to check it. Everything went well, but when I started, the needle shot up to about 40-45 PSI. Then it began to drop till it read zero. I have 4.5-5 quarts of oil. There is NO motor noise, its running VERY smoothly. The only complaint I may have is the rockers are a little noisy. (SLIGHTLY more then normal, similar to the first 5 seconds of a cold startup). I don't get it... Is my oil pump done? Is my motor toast? Please give me good news! lol
bill302
2,131
alabama,gadsden
Jan 5, 2006
  • Jan 5, 2006
check oil pressure sending unit and switch. pump could be good and sending unit and/or switch could be bad run a search there was a thread a few days ago telling how to test unit.
fox racer
577
Staten Island, NYC
Jan 5, 2006
  • Jan 5, 2006
Im swappin the pump no matter wat, Im taking the tranny already out, and the exhaust and motor mounts out too (long tubes, new trans/motor mounts and TOB bearing). Hows this oil pan gasket? FMS-M-6710-A50 at summitracing.com . Im getting a Melling stock replacement w/ a new driveshaft too.
RyanSG
286
Allentown, Pa
Jan 5, 2006
  • Jan 5, 2006
Yeah sounds liek somethings up with the pump. It's either clogged or shot. Either way an oil pump isn't to much so if your ripen it apart you got it right and just replace it with another one. I would just get the upgraded pump shafts since their a little thicker/stronger.
fox racer
577
Staten Island, NYC
Jan 5, 2006
  • Jan 5, 2006
Thanks ryan, thats what i was figuring. wat you think of that gasket?
69Rcode_Mach1
1,473
Salt Lake City, Utah
Jan 5, 2006
  • Jan 5, 2006
Switch that oil pump ASAP!!!! Then start it up and see where your pressure is. I had a new oil pump die, and the car ran for a minute without oil pressure which was enough time to allow the cam to grind some clearance in the bearings. So when I replaced it I ended up with low oil pressure no matter what, and now the engine is coming back out. Do this first and make sure you didn't damage bearings, then if need be take out the engine with the tranny and fix this because you will destroy that whole engine if not.
fox racer
577
Staten Island, NYC
Jan 5, 2006
  • Jan 5, 2006
thanks alot rcode, will do. Can anoyne help me witht hat gasket? i need to order tonite if i want my stuff saturday.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 5, 2006
  • Jan 5, 2006
dont forget a new screen while your at it along with a new oil filter (motorcraft) ........and have fun trying to do it in the car ......ive done this before it the stock K member is not forgiving
fox racer
577
Staten Island, NYC
Jan 5, 2006
  • Jan 5, 2006
I figured that... im liftin the engine, dropping the tranny and basically pulling it, but keeping it in the engine bay.
aleborjas
610
#10
  • Jan 6, 2006
  • #10
i had that problem before and it whas a ****... fram oil filter put back stock one and problem gone i only use motorcraft and purolator!
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
C
Engine Oil pressure issue
  • Cg’s 347
  • Jan 15, 2024
4K
Fox 5.0 Mustang Tech Mar 2, 2024
AeroCoupe
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
G
oil pressure
  • Gandalf79
  • Feb 5, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 12, 2024
Gandalf79
G
