No Pink/black Wire On Fuel Pump Relay
I'm pretty sure my fuel pump relay should have a pink wire with black stripe on it. The harness is from a 93. But the wires on the relay are red, green/yellow, orange/black, and another one that looks green/yellow, but I'm color blind, so hopefully my common sense has the colors pretty close. I'll post a pic when I get home tomorrow night if I need to. But there's definitely no pink/black wire, and it's definitely the fp relay and not the a/c cut off relay.
Anyone know why this is?
You are color blind and trying to identify wire colors? That does not sound good.
What you think you have and what you have may be two different things.
92-93 5.0 Mustangs had 2 relays under the hood: one relay was A/C compressor WOT shutdown, the other was the fuel pump relay.
The 88-early 91 had one fuel pump relay under the driver's seat.
Is there a fuel pump relay under the driver's seat?
If so, check out this diagram: 88- early 91 fuel pump wiring
87-90-5-0-mustang-fuel-pump-wiring-gif.88241
No fuel pump relay under the driver's seat:
Check out this diagram: late 91-93 Fuel pump wiring
Diagram Courtesy of Tmoss and Stang&two birds
Use the diagrams to help you determine which wiring you have. Find someone to help identify the colors if necessary. Clean the wiring off with some gasoline or solvent that doesn't melt plastic before trying to identify the colors.
Thanks J, but being color blind isn't as bad as some people seem to think. It's not all black and white. And I have been looking at those diagrams for quite some time from some of your previous posts, and as you can see, there's a pink/black wire on the fuel pump relay no matter which one you look at. And even an org/lt. blue on both. That's why I'm making this thread. I had a friend verify the colors I posted, but that was from a picture, and I'm sure of the org/blk, red, grn/ylw wires, but the 4th wire (that I said could also be grn/ylw) could easily be other colors like brn/org, but there's definitely no pink/blk. For reference this is in the engine bay (next to the a/c cut off relay).
Yes, there is a relay also under the seat. And the car is a 90. I also know that's a year all by itself when it comes to harnesses. I'm just trying to confirm why there's no pink/black wire at the relay. I'm really not looking forward to dropping hundreds of dollars for another harness. They're not easy to find either.
The relay under the seat may be the one that operates the fuel pump. Focus your attention on it and see if you have voltages on the proper wires.
Fuel Pump Troubleshooting for 87-90 Mustangs
Revised 10-Aug-2012 to update fuel pump run time on initial startup
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 1-3 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the upper LH corner to ground.
Turn the ignition switch on when you do this test.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most Mustangs built before 92. See the diagram to help identify the fuel pump relay wiring colors. Be sure to closely check the condition of the relay, wiring & socket for corrosion and damage.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). Notice that pin 19 on the computer is the monitor to make sure the pump has power. The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
attachment.php
Now that you have the theory of how it works, it’s time to go digging.
All voltage reading are made with one voltmeter lead connected to the metal car body unless otherwise specified
Check for 12 volts at the red wire on the inertia switch. No 12 volts at the inertia switch, the ignition switch is turned off or faulty or there is no power to the ECC (computer ) power relay. To be sure look for good 12 volts on the red wire on any fuel injector:
good 12 volts mean the ECC relay is working. No 12 volts and the ECC wiring is at fault.
Look for 12 volts on the red/green wire on the ignition coil: no 12 volts and the ignition switch is faulty, or the fuse link in the ignition power wire has blown. No 12 volts here and the ECC relay won’t close and provide power to the inertia switch. Check the Red/black wire on the inertia switch, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open. Push the button on the side of it to reset it, and then recheck. Good 12 volts on one side and not on the other means the inertia switch has failed.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition switch wiring or connections. There is a mystery connector somewhere under the driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Pump wiring: Anytime the ignition switch is in the Run position and the test point is jumpered to ground, there should be at least 12 volts present on the black/pink wire. With power off, check the pump ground: you should see less than 1 ohm between the black wire and chassis ground.
attachment.php
The yellow wire is the fuel tank sender to the fuel quantity gage. The two black wires are grounds. One ground is for the fuel tank sender and the other is the fuel pump. The ground for the fuel pump may be larger gauge wire that the fuel tank sender ground wire.
Make sure that the power is off the circuit before making any resistance checks. If the circuit is powered up, your resistance measurements will be inaccurate.
You should see less than 1 Ohm between the black wire(s) and ground. To get some idea of what a good reading is, short the two meter leads together and observe the reading. It should only be slightly higher when you measure the black wire to ground resistance.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect. Remove the test jumper from the ECC test connector located under the hood. Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer and everything else is connected. Turn the ignition switch to the Run position and observe the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn the key to the Run position. This can sometimes fool you into thinking the computer has died. Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin. With the ignition switch Off, jumper the computer into self test mode like you are going to dump the codes. Turn the ignition switch to the Run position. The light will flicker when the computer does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
Fuel pump runs continuously: The fuel pump relay contacts are stuck together or the Tan/Lt Green wire has shorted to ground. In extreme ghetto cases, the pump relay may have been bypassed. Remove the fuel pump relay from its socket. Then disconnect the computer and use an ohmmeter to check out the resistance between the Tan/Lt Green wire and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
If all of the checks have worked OK to this point, then the computer is bad. The computers are very reliable and not prone to failure unless there has been significant electrical trauma to the car. Things like lightning strikes and putting the battery in backwards or connecting jumper cables backwards are about the only thing that kills the computer.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
back when I first realized that the relay was under the seat, I tested it then for power, and had nothing. I could check it again just in case I missed something, like not having the key on or something.I do know, at the relay in the engine bay, that with the key off, no wires have power, but with the key on two of them had power. I don't remember which ones. I'll have to go back and check.
Here's one relay in the engine bay. You can see the other one behind it. I'll post that one next.
This one looks to have a red, blk/ylw, org/ blu, and my daughter says the other looks org/ylw.
Update...
Key off=none of these have power
Key on= red has 12 volts. Other 3 have .15, .01, and .01
This is the other relay next to the last one. Org/blk, Red, Blu/org, and grn/ylw.
Update....
Key off= org/blk has 12 volts. Others have nothing
Key on= grn/ylw has 4 volts, org/blk still has 12, red now has 12, and the blu/org has .05 volts.
Start checking for voltage with the ignition switch off. One wire on the second relay should have 12 volts.
With the ignition switch on, 2 wires should have 12 volts if the relay is working correctly.
The red wire gets power from the computer power relay. That's a good start.
Look for a dark green/yellow wire on the relay. That is for the ground that the computer provides to turn on the fuel pump. Jumper it to ground and then turn the ignition switch to Run. If the relay is working OK, you should have 12 volts on one of the remaining heavy gauge wires. That indicates the relay and power feeds are working OK. No 12 volts, and the relay isn't working correctly.
So I jumpered the grn/ylw wire to ground. You said one of the "remaining heavy gauge wires" should have 12v. Meaning "either the org/blk, or red wire", or did you mean the "last wire left"? Just trying to clear it up because "the last wire (blu/org)" just isn't as heavy of a gauge as the rest. Either way, after jumpering the grn/ylw wire, with the key in the run position, there is no change. Org/blk and red both still have 12v, grn/ylw is jumpered to ground, and blu/org has .05v
So, in my case, the org/blk wire has the constant power source. Then the relay receives it's signal when the key is turned to the "run" position, which lets power continue to the red wire.
You got it right. Follow that logic and check to see what is missing at the relay.
Nothing seems missing at the relay. Org/blk wire has power before the key is turned on, then when I turn the key on, it opens the relay which sends power through the red wire. So I need to find out where the red wire goes. But since my harnesses are from different years, I would need some type of diagram showing which wires are which at each of the connectors on the harnesses.
