  • SN95 4.6L Mustang Tech
NO POWER!!!
  • Thread starter Thread starter scooter6753
  • Start date Start date Jul 28, 2004
scooter6753
101
maryland
Jul 28, 2004
  • Jul 28, 2004
Guys im losing horses somewhere and im not sure where...but i need help. I have a 99 gt vert 5 spd, bone stock. I know how to drive i know where my shift points are and im running thru gas the way i expected. But im lagging somehwere. I got owned the other day by a del sol running a 50 shot of giggle gas. I shoulda had him, i got destroyed today by an s2000. Now i know i need to replace the airfilter but whatelse do i need to be lookin at because this rice burner crap is really pissing me off.
GTvert01
636
West Plains, MO
Jul 28, 2004
  • Jul 28, 2004
Start building is the best advice I can give you. Maybe you need a tune-up Throw some gears in the vert and make it a whole different car
stang976
853
Westchester, NY
Jul 28, 2004
  • Jul 28, 2004
compression test??
V
vidmaster
167
Brick, NJ
Jul 28, 2004
  • Jul 28, 2004
plugs, fuel filter. also might want to pay for a dyno and see if you are running too lean/rich. i doubt you need a tune with your mods but its possible. you could also be losing power from something else, or maybe you're not as good of a driver as you think (no offense)
If you think you are running lean or getting pulled timing, try higher octane gas. I think my car was running lean because it runs way better on 93 than 89 octane. Cut a 14.5 @ 95 from a 1500 launch on my first ever 1/4 run with the 93. (thats full weight with spare/jack and my amp/subs
scooter6753
101
maryland
Jul 28, 2004
  • Jul 28, 2004
alright...i will do a compression test...also to order this week hopefully a list of parts spec stage 2 clutch, aluminum drive shaft, 4.10 gears, densecharger, 70mm throttle body quad clutch cable adjuster. Does this sound ok?
GTvert01
636
West Plains, MO
Jul 28, 2004
  • Jul 28, 2004
You will need a speed cal, chip, programmer, or tune to fix your speedo after the gear install.Personally, I think you should skip the throttle body and driveshaft for now.Just my .02. Go with Steeda underdrives and maybe a shifter.
scooter6753
101
maryland
Jul 28, 2004
  • Jul 28, 2004
i already have the speed cal...ill get the chip too...i figure if im gonna do the drivetrain im not gonna do it in pieces im just gonna do it all at once and get it over with.
Go HoTO!
602
Mountaintop, PA
Jul 28, 2004
  • Jul 28, 2004
If you are havng a problem with the car, you should try to find it before piling mods on. seriously, do you think there is a problem with the car? Run it at the track or get a g meter to see how it is really running. If you are not at least in the mid 14's, then I would agree that there may be a problem.
Silver2003Cobra
21
  • Aug 8, 2004
don't feel bad about being beat by the S2000, since it weighs 600 lbs less than your car and is only down 20 hp.. (and your body kit is only making that weight difference worse)
12.99 lb/hp for Stang GT ragtop
11.70 lb/hp for S2000
now the Del Sol, not sure about that one, since I don't know what they have for power before the laughing gas..
J
jbrown
393
Tallahassee, FL
Aug 9, 2004
#10
  • Aug 9, 2004
  • #10
a throttle body will only help if you get a plenum as well, get a shifter, the densecharger didnt do me any good I wouldnt do it again. Do a tuneup before buying mods, spark plugs, air filter, fuel filter, and see if it helps. Are you just getting beat or do you think there is something wrong with your car? I had an ignition coil go bad, my car was misfiring bad very noticeable.
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Advice after break down.
  • bjornsn95
  • Jan 17, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
please help! not a typical coyote swap
  • sarver24
  • Nov 15, 2024
  • Other Auto Tech
Other Auto Tech Nov 15, 2024
manicmechanic007
