No start after mass air conversion.....
fordman54935
301
Wisconsin
I finished up the conversion on my 88 GT 5-speed with an A9L computer, C&L 73MM MAF, and an IST conversion harness, but now the car will crank but will not start. I have fuel and spark. All connections were soldered/insulated with heat-shrink tubing. The VSS wires are hooked up and the MAP sensor vacuum lead is plugged. Anyone have ideas/suggestions? Thanks!
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Thanks for the very informative post jrichker. I printed that one off for future reference. :nice: I followed that list and I'm starting to think it is the EEC computer that is to blame (bought it on ebay, hope I didnt get screwed).
I've covered all the basics ands here is what I've come up with:
- Spark present at plugs.
- Ignition timing set to 10 deg BDTC, SPOUT connected (after the timing was set)
- Fuel pump cycles when key is on, 40 PSI @ rail.
- EEC relay is good, 12 volts present at 60-pin EEC harness plug.
- 12 volts NOT present at injectors, it is my understanding that there should be 12V at the injectors at all times when the key is on.
- No failures/breaks in the injector harness.
From what I've read, fuel injectors need 2 things to operate: a constant supply of pressurized fuel, and a steady 12 volts DC. From there the computer decides the pulsing of the injectors, correct? I know its easy to blame the computer when there is something else causing the problem, but I've checked every freakin electrical connection in the car and all is well.
So now the question is: How (or where) can i go to get this computer tested? Is it something that a dealership could do without screwing me? I've gone through this whole thing eliminating one possibility at a time, and this is the last one. I just really hope I didnt get screwed buying this computer on ebay. Thanks again for the help Jrichker.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
The following tests are run with the ignition switch in the Run position.
No 12 volts on the red injector wiring means that the black & white 10 pin
connectors are suspect, or the EEC relay or wiring for the ECC relay is bad.
Look for 12 volts on pin 1 of the black 10 pin connector. Look for 12 volts on pins
37 & 57 of the 60 pin computer connector. No 12 volts and the EEC relay has failed.
Update....
I figured out why I didn't have 12 volts at the injectors - it was an oversight on my part - an intermittent connection at the black 10-pin connector on the upper intake, however I still have no start. I checked injector pulse with a noid light and sure enough the injectors arent firing. I'm now positive that the computer is at fault. I was also unable to pull ANY codes from the diagnostic link, not even a "1-1" or "1-1-1" PASS code.
