no2
Yep the lincoln engine is the one I want to put it on...... and I dont really care what happens to this particular engine either cause I have another out of a 93 car with a forged bottom end. The local track is about to open and I just want to go and play with the car in stock trim and then a little juice on it to see what it will turn before I take it off the satreets for a good tune and a paint job. So if I om the engine it wont bother me.
Thanks,
Nate
well i thought the lincolns did not have H.O. motors/(cam)...
anyway. your question is pretty broad.
you need colder plugs, you need to take 2 * of timing out for ever 50hp you want to spray.
buy a nitrous kit and follow the directions.
im not sure exactly you want to know. search the forum or starting reading threads in the "power adders" section of this website.
You are correct, Lincoln doesn't have an H. O. unless it maybe in a Mark VII. I am still running the non h.o. firing order, so I know that I am losing power there. The info yall gave is what I was looking for/.
