Noise In Rear End
pursuit
memphis tn
HELLO VERY VERY NEW TO SITE PLEASE HELP BOUGHTA 89 LX 5.0 NOTCH NOISE IN REAR END SOUND LIKE BRAKE RUBS THE GUY WHO SOLD SAYS GEAR IS WORN ITS A SSP 174K KOOKS XCELLENT ARE GEARS EASY TO INSTALL AND AROUND WHAT PRICE :) :) :spot:
Welcome to stangnet!
what does the noise sound like to you though? it could just be bearings, they make a moaning sound like a wahhh wahh wahhh wahhh wahh...gear noise is typically a speed variable whine....
gears can be had for cheap if you look hard enough, they are normally about $170-$185 a set new, depending on where you look. Installing them-unless you've got an angel sitting on your shoulder, a pinion depth checker, and a dial indicator gear install is a very precise process...better off taking it to a shop.
they should be less than $150 to install though
Have you considered it might not be the rearend at all, and might be a problem with the drum brakes?
I had a awful metal on metal grinding noise awhile back that turned out to be the adjusting lever having broken off and was rubbing against the drum...
Just an idea...
