Noisy clutch cable after quadrant + firewall adjuster install ?
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
I had problems since last year with the clutch. It was grabbing way too high.(right on top). I changed the clutch, brand new flywheel, tranny has been opened up last winter (everything was perfect). I just installed a UPR triple hook quadrant(middle position I'm using), with a Xtreme Firewall adjuster, this morning. I adjusted it ok. Now it grabs in the middle and I can actually make the car "move" just with the clutch, without touching the gas. But now I'm hearing some weird noise under the dash. It sounds like the cable over-stretching or something...Everything looks fine but its very annoying.
Is this normal with aftermarket quadrant and firewall adjuster ?
The only thing I didnt change related to the clutch is the cable..Is it finished ?
Any help appreciated.
thanks
