Noisy lifters in my 1965 mustang
mustangguy65
27
California
Ive got a little problem i hope . I own a 65 mustang coupe mild 289 build 351 heads, Stock 289 push rods, Stock crank, Mild cam, Stock roller rockers non adjustable .The lifters are making a little noise could it be the stock push rods ? and if it is the push rods witch push rods do i need ?
push rods 302
push rods 351
Thanks
Valvetrain geometry is critical. If you get it wrong it could cause bad problems. The only Windsor engine I know of with stock roller rockers is the '93 - '94 Cobra 5.0L. Adjustable roller rockers require guide plates, which might be included in the stud kit.
The question we have all failed to ask is:
Did the lifters just start making noise after being fine for while?
OR:
Have they always been a little noisy since putting this combo together?
FYI, the Ford Racing/Crane roller rockers DO make a little noise, as do most roller racker arms.
HTH,
Gene
With the warmed up(and engine off) remove the valve covers. Since they are hydraulic you can probably do this cold, but warm would be better.
Start with #1 cyl at TOP DEAD CENTER ON THE COMPRESSION STROKE.
Take a feeler gauge and try to slip it in between the rocker arm and valve stem tip.
With hydraulic lifters you should have 0 play (valve lash).
Any play is what is making the noise. Since you changed heads you will need either longer pushrods. or adjustable rocker arms.
The pushrod length is to center the contact area of the rocker arm over the valve stem. If this is currently centered, then keep you push rods and get adjustable rocker arms.
If the tip of the rocker arm is NOT centered over the valve stem, then you need to get adjustable pushrods to measure the current length, and then buy a set of pushrods that length. (I think the adjustable rods are only for engine building)
6. To check and adjust the lifter preload, turn the bolt by hand until
there is no clearance between the front roller and the valve stem
and the pushrod is seated in the rocker arm pushrod seat. Slowly
torque the bolt to 18-20 ft/lbs. Since you are pushing down the
plunger in the hydraulic lifter as you torque the bolt, it will probably
take a minute or two for you to get the correct setting. You
should be able to turn the bolt between 1/4 & 1 turn before you
reach the correct torque setting. This will give you the correct lifter
preload of .020" to .060". If you can turn the bolt more than one
turn to achieve the proper torque, you will have to shim the
pedestal. Two different thickness shims are provided for each
rocker arm to assist you. A thick shim represents approximately
one turn.
If you cannot turn the bolt at least 1/4 turn after first contact with
the roller and valve stem, you will have to install longer pushrods
to obtain proper hydraulic lifter preload. Pushrods are available in
different lengths, specifically for this purpose. There are many
modifications that may have been made to the engine which will
change the lifter preload, such as a valve job, different camshaft,
or different thickness head gaskets, and factory tolerances can
also affect the lifter preload on stock engines.
