Engine None egr gt40 intake upper and lower install on a stock foxbody
Ok I need a little help please I've got a 93 convertible mustang gt with automatic transmission I ran across some gt40p heads and upper and lower none egr intake I'm wanting to install it on my stock motor only thing done to it is 70mm throttle body and cold air intake and alternator upgrade also new injectors and bbk mass air meter I've got a super chip added to it also I'm about to do the electric fans and radiator and long tube headers but what I'm needing to no is what all is involved in installing the heads and intake?? If anyone can help me please thanks
The P heads require specific headers to clear the spark plugs so make sure the ones you get will fit. I would also recommend replacing your timing chain while you’re in there. A set a ARP head bolts would be a good thing too.
Changing heads is a time consuming job but not hard. The biggest thing is to get the deck of the block extremely clean and the mating surfaces of the heads. Don’t use a Scotch bright pad or anything else that could leave stuff that would end up in your engine.
I like to use the Explorer intake gaskets the have the silicone China rail gaskets. As I’ve found them to not leak and last a long time.
Use the proper RTV gasket maker. Permitex makes RTV for parts that come into contact with oil (black) and coolant (gray). Also make sure you use thread sealer on the head bolts that go into the water jackets.
One other tip. Go to the hardware store and get 4 bolts that are the same thread and size as the lower intake bolts and above 2 1/2 -3” long. Cut the heads off of them. When you go to install the lower intake thread them into the heads for a guide. They will guarantee that your lower intake gaskets doesn’t slip and make your life much easier.
Let us know if you have any specific questions.
  • Useful
Reactions: General karthief
