Note to self... make brake lines before engine install.
  • Thread starter Thread starter 68converted
  • Start date Start date Oct 25, 2006
68converted
772
Colorado
Oct 25, 2006
  • Oct 25, 2006
M
mustangman70
1,235
St pete, Florida
Oct 25, 2006
  • Oct 25, 2006
Whoops lol
Thanks for teaching me that before i had to teach myself!
blue65coupe
71
North Carolina
Oct 25, 2006
  • Oct 25, 2006
+1 I'm in the same situation myself right now
68converted
772
Colorado
Oct 25, 2006
  • Oct 25, 2006
Man this is a drag! I did figure out that using a tube bending tool is just about useless. I have been making my bends around various size pipes, works pretty well.
LMan
1,246
Mom's basement
Oct 25, 2006
  • Oct 25, 2006
engine is the LAST thing you install
68converted
772
Colorado
Oct 25, 2006
  • Oct 25, 2006
Yeah, until you find out the MC is F'd up and the lines are rusted solid, and you strip the nuts to holy heck and you get pissed and start busting a gasket, and then you give up and start cutting lines. Yeah, it sucks.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 25, 2006
  • Oct 25, 2006
Maybe you are using one of those crappy ones ? I used a few different tools I borrowed from people and was very unhappy with them all until I found the "pliers type" tube bender. This sucker has always done right by me, works like a champ. I even had a few people ask me if the lines I made were factory lines the bends were so good =)
joesgt281
163
Katy, TX
Oct 26, 2006
  • Oct 26, 2006
and I'm adding a line-loc and an adjustable proportioning valve
68converted
772
Colorado
Oct 26, 2006
  • Oct 26, 2006
Mine was about $40 bucks, not sure if that is crappy or not, but it was the only unit that 4 diff parts stores stocked. I found that using one of those fat rubber gripped screw drivers works awesome. (at least for the 1/4 and 3/16th) tubes). Nice tight bends too. For the bigger tubes that I am doing the AOD lines and the bigger stuff for Fuel EFI, the bender is much better.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 26, 2006
#10
  • Oct 26, 2006
  • #10
The one I have is the one that looks like a pair of pliers (the top one). The other rounded one sux. I've never been able to use them with any success.
http://cgi.ebay.com/2-TUBING-BENDER...tter-pipe_W0QQitemZ130037203524QQcmdZViewItem
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 26, 2006
#11
  • Oct 26, 2006
  • #11
double posted, sorry
Tim65GT
1,149
West Texas
Oct 27, 2006
#12
  • Oct 27, 2006
  • #12
I have the top one too and didn't use it for the 3/16 steel brake line. It bends rather easy without kinking.
I bent a one peice 3/8 steel fuel line from front to back along side of the brake line. I needed the tool for that, but I was cursing it the whole time I was using it. It's just a cheap peice of crap.
I ended up mounting the wheels on a jig in my vise. I'm sure ther is a better tool out there, but for as much tubing as I bend, I can put up with the cheap crap.
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Oct 27, 2006
#13
  • Oct 27, 2006
  • #13
Don't tell me that! (Which I already knew)
Guess what I'm starting this weekend.
68converted
772
Colorado
Oct 29, 2006
#14
  • Oct 29, 2006
  • #14
my only suggestion is to use a 16" piece of hanger wire to mock up the bend you want to do then bend away. Also, you can aways bend away from a tight area then twist or rotate the tube into position. This is how I was able to keep mine close to the trans and engine without shooting myself.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 29, 2006
#15
  • Oct 29, 2006
  • #15
A hanger ? Thats a great trick.... I'll have to remember that =)
Marshall
225
Qld Australia
Oct 30, 2006
#16
  • Oct 30, 2006
  • #16
For you guys who intend to keep your Stang forever or run on salty roads fitting the stainless brake line nuts is a good idea. So too is stainless brake lines.
You will probably have to get the flares done at a brake shop if you use stainless lines as the tube is too hard for a 'home' flaring tool.
M
BB1966
297
Beaufort , NC USA!!!!
Oct 30, 2006
#17
  • Oct 30, 2006
  • #17
I bent all my lines out of stainless and flaired them....there is NO way I would try it if the engine was in. I even put the adjustable prop valve inside by the driver seat.
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
