About a month ago, i put on some Chrome bullitts from wheel replicas, and around the same time i developed a noticeable exhaust leak.
Also, around this time i decided to clean my engine with some degreaser and a spray hose... When i was done cleaning the engine i blew it dry with a leaf blower and drove the car home. I noticed on the way home that the car would actually have dead spots at WOT, where i would have the gas pedal all the way down, and it would have 2-3 short periods of no pull accelleration throughout the rpm band in each gear. So i got the car home, and not knowing exactly what i was doing decided to unplug the MAF sensor on the intake, it had some water in it, so i blew it out and reconnected it. car sat overnight, and since then the car has no "dead spots" during acceleration and runs fine, but seems to me to have a slightly noticeable decrease in power...
Honestly i cant decide if i screwed something up in the engine, or if its the combination of the heavier wheels and tires/FLorida heat and humidity/ exhaust leak.
What can i check and where can i start to fix the problem? What do you guys think?
Also, went to the track for the first time, here are my times:
R/T: .791
60': 2.319
330: 6.502
1/8: 9.807
MPH: 72.58
1000: 12.6
1/4: 14.986
MPH: 95.78
Is it possible for the chrome wheels to add as much as .3 to .5 to my times???
R/T: .791
60': 2.319
330: 6.502
1/8: 9.807
MPH: 72.58
1000: 12.6
1/4: 14.986
MPH: 95.78
So i cant put the stockers back on... I was thinking of buying some Drag radials and keeping the stockers for the rear.... I have a feeling though that it is because of the wheels/tires, and as for the times, couple this with it being my first time and you get the idea...
