Noticeable decrease in power, cant pin it to one particular reason, help me!
BigChiefSmokem
1,400
Jacksonville, FL
About a month ago, i put on some Chrome bullitts from wheel replicas, and around the same time i developed a noticeable exhaust leak.
Also, around this time i decided to clean my engine with some degreaser and a spray hose... When i was done cleaning the engine i blew it dry with a leaf blower and drove the car home. I noticed on the way home that the car would actually have dead spots at WOT, where i would have the gas pedal all the way down, and it would have 2-3 short periods of no pull accelleration throughout the rpm band in each gear. So i got the car home, and not knowing exactly what i was doing decided to unplug the MAF sensor on the intake, it had some water in it, so i blew it out and reconnected it. car sat overnight, and since then the car has no "dead spots" during acceleration and runs fine, but seems to me to have a slightly noticeable decrease in power...
Honestly i cant decide if i screwed something up in the engine, or if its the combination of the heavier wheels and tires/FLorida heat and humidity/ exhaust leak.
What can i check and where can i start to fix the problem? What do you guys think?
Also, went to the track for the first time, here are my times:
R/T: .791
60': 2.319
330: 6.502
1/8: 9.807
MPH: 72.58
1000: 12.6
1/4: 14.986
MPH: 95.78
Is it possible for the chrome wheels to add as much as .3 to .5 to my times???
well for one, you will feel those wheels, put the stockers on there and compare if you want, but they definately slow you a bit, .3 or more is not unreasonible. of course, the weather and driving can come into play as well. clean the maf, very carefully with alcohol, water can leave a residue. that exhaust leak, unless its very major, is not much more than an annoyance. for cleaning the engine, i would not spray it with water, but thats just me. there is a chance you could have fried something, maybe a sensor. but i think it is unlikely.
If i fried something, would there have been a SES Light on?
thats what im thinking too. take it to a shop and have them do a once over on the engine, see if they can find out wahts going on...but first put the stockers back on and see if you feel any more get up. if the wheels are heavier than the old ones, that means more rotational mass, resulting in slower times.
Well, the stockers dont have tires on em, as i was going to sell them, and took the tires off. :( So i cant put the stockers back on... I was thinking of buying some Drag radials and keeping the stockers for the rear.... I have a feeling though that it is because of the wheels/tires, and as for the times, couple this with it being my first time and you get the idea...
