If you've read any of my other posts you know that I've been trying to set the timing on my stang, but the 0 degree mark on my balancer and the real TDC are not lined up right. So I figured that the balancer wasn't installed correctly. I just pulled the balancer off and it turns out that its keyed to only fit one way. So it must be some other problem, but I have no idea what it could be.
I put a mark on the balancer where the real TDC is with white paint, I also put a mark where TDC should be. Take a look at the picture at the link below to see the 2 marks.
http://www.wowway.com/~kevinrush1/balancer.jpg
I set the car to the real TDC before I pulled the balancer off, I may have rotated the crankshaft a few degrees when I broke the crankshaft bolt loose though. This is where the distrib is pointing now. (Almost at the #1 cyl)
http://www.wowway.com/~kevinrush1/dizzy.jpg
And this is where the nose of the crankshaft is pointing
http://www.wowway.com/~kevinrush1/seal.jpg
What could cause the marks to be off like this? Any ideas?
Also, Here's a pic of the back of the balancer if it helps any
http://www.wowway.com/~kevinrush1/balback.jpg
Really don't know what to tell ya at this point.. You say the car won't run when you line up the zero with the pointer?? Again not too be an a$$, but you are sure its the #1 plug you pulling out????(1st plug on passenger side) Just making sure we are on the same sheet of music here....If for some reason you are pulling the 5 plug then thats about where the rotor should be pointing in the pic you have posted...Unless someone esle has down some work on the car and instead of setting the dist correctly , they walked the wires to make it run....
