  • SN95 4.6L Mustang Tech
NPI Intake Install How-To?
  • Thread starter Thread starter d98gt
  • Start date Start date Apr 11, 2005
d98gt
4,505
59
204
SE Texas
Apr 11, 2005
  • Apr 11, 2005
Since the server went down, I don't believe this is still on the site. I will be performing a NPI Intake install Friday, and a how-to (pics would be great) is needed.
I know there used to be one, though I don't remember the site/link. Thanks for any helps guys!
LI98GTStang
1,715
L.I., NY
Apr 11, 2005
  • Apr 11, 2005
Here's one that was from a guy with an NPI Crown Vic. Most applies (not the windshield cowl removal etc...) to 96-98 stang PI intake swap. Shout out if you need (over the internet) assistance.
http://www.redpulsar.us/~coldfusion/intakeswap.html
And another excellent link from the other site.
http://www.corral.net/forums/showthread.php?s=&threadid=452312
d98gt
4,505
59
204
SE Texas
Apr 11, 2005
  • Apr 11, 2005
Do I need EVERYTHING listed on the crown vic site?
How long did it take you to do your install?
What I am most worried about is getting everything looking like it does now, and not having wires everywhere
LI98GTStang
1,715
L.I., NY
Apr 12, 2005
  • Apr 12, 2005
If I remember right, it took me 5-6 hours start to finish. I had gotten some radiator fluid down in the cylinder ports when I lifted off the intake so I had to get a wet/dry vac to get it all out, which was a pain. The PI intake swap does require some work though. I took the easiest way out and ordered the parts to make the swap easier i.e. coolant tube, altenator bracket and purchased a PI intake that was drilled out for the second sensor. You can do the swap a little cheaper by not getting those extra parts, but it will take you longer to do the install such as the stock altenator bracket can be modified by drilling out the proper hole locations etc, a flex coolant tube can be used and cut to length instead of the 99+ hardened version.
I also changed the waterpump nipple, but found that mine and all '98s that I've seen have already had been upgraded to the newer version that connects to the new coolant tube with no modifications.
Don't worry, when your done, it looks stock and wires aren't everywhere.
Here is my engine bay immediately after the install. I have since routed the drivers side plug wires over the thermostat for an even cleaner look.
mr. jones1
102
NJ
Apr 12, 2005
  • Apr 12, 2005
Try my site I have write up and pics.
Its plates and manifold on a 1998 GT
www.unitedmajority.com
d98gt
4,505
59
204
SE Texas
Apr 12, 2005
  • Apr 12, 2005
Thanks alot for the info guys.
Im just going back with the NPI intake, but this info/write ups are great
Thanks once again
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
