O-Ringed Heads?
Black Sun 5.0
1,337
L.I., N.Y.
I was looking at some Edelbrock Performer heads online and noticed that they offer an "o-ringed" version of the same heads designed for supercharged and NOS vehicles. What are the pro's and con's of these heads vs. the standard ones? I ask because I keep talking myself out of upgrading my heads again but I do plan on a supercharger in the future.
The pro of O-ringed heads is that they don't blow headgaskets easily. The downside is that now instead of blowing just your headgasket, you have more catastrophic failure, should something go awry in the combustion chamber. Typically those using O-ring heads are using upgraded components in the short block that will withstand the factors that caused the person to use the O-ring head gaskets in the first place. I wouldn't personally use them on a stock short block, just for the piece of mind that I may save it from meltdown by losing a gasket instead.
You just have to know the limits of your engine. A 200 shot NOS will blow your stock shortblock either way. The non-oring headgaskets can create a failsafe but you can't depend on that if your engine wasn't up to the task in the first place. I opted for the o-ring heads to make sure that the gaskets never blew agian(what started my whole H/I/C).
Kevin
Kevin
