OBD-II in a '95 V6?
thesargster4
23
Hey guys. Finally got her up and running, two days later... its still running strong but i got a check engine light.. I notice an OBD-II port under the dash, and i've tried two OBD-II readers, and they dont even get power.. Am i missing an older type port, or what could be going on? I dont think the PCM is fried, its running to good for it to be..
Thanks!
John
...which means that you can pull any codes using the jumper wire method. The procedure is in the service manual. OBD-I is not as comprehensive in helping you with diagnostics, but at least it's easier to pull codes since you don't need a reader.
the car is not obd-II,96 and up are obd-II my wife has a 95gt and it has the plug under the dash but it was never hooked up from the factory,the test plug u need is on the pssenger side fender close to the a/c stuff on the firewall.u can buy tester after tester for the obd-II and it will never work,its obd-I,only 96 and newer vehicles are obd-II.the plug under the hood should have a black cover and say eec test.it has a big plug and then a small grey plug.
It totally depends
It's OBD-II, i agree on that one. See, 95 was the last year of obd-I support, and was the transition to obd-II in 96. Now, some cars (not all) used obd-II systems in 95, and was usually found on higher end cars, like the mustang, corvette (hate em), etc... you get the picture. Seriously, 95 was a very funny year for alot of cars concerning obd-I or obd-II support. My 95 mustang V6 is OBD-II.
the obd 2 port under the dash is actually for the gem module >95 is still obd1 and the connecter will be under the hood
94 & up V6 stangs are OBDII
94 & up V6 stangs are OBDII 5.0's are not. I had a 95 v6 vert & it was definitely OBDII as I used the port under the dash with my OBDII scanner. the same scanner that I still use on every car in my household except for my 95 GT.not sure why there is no power at the port but take it to Advance or Autozone & see what they say.
Thank you 393Stroker. Fact!
94-95 GT's, which have the 5.0 302 engine are EEC-IV (aka OBD I). The 5.0's are the ONLY Stangs with OBD-I pcm's. The 94 and up 3.8 V6 Stangs are ALL OBD-II systems. The only thing different between the 94-95 V6's and the 96 and up V6's is that the 94-95's still contain Ignition Control Modules, while the later ones don't. It's all built in to the PCM on those. There are a few other differences, but I wont get into that..way off topic.
So 94-95 V6 people, go ahead and fire up that OBD-II scanner. If no scanner will work when plugged in, either there is a wiring problem on the data connector, or a faulty sensor is overloading the PCM. A no read display will occur if this IS the case. Unplugged sensors wont cause a no-read situation. It will just throw a code for no signal, no voltage, etc.
When I turn on my key I have no light that test to check engine light so I don't know if it works or not how do I find out. My car is running rough after head gaskets. Acts like it's missing spark plugs smell like gas . No check engine light
The CEL should come on when you turn the key to on and do not start the engine. If it doesn't it's possible that the bulb is burned out.
With it being a V6 and having OBD2, you can plug in an OBD2 scanner and it will read codes/data/etc. That would be the first step I would take
Why would I think it would be that easy. Wasn't sure saw obd2 looking plug but didn't think obd2 came out till 1996.
