obd1, and obd2 ports
94-95's have OBD-I and OBD-II ports. The V6's are OBD-II so both ports are present (they use the ALDL for OBD-II and we use the underhood one for OBD-I).
This is 100% correct. The dash is identical between all the 94-95 models, except for the instrument cluster of course. The connector is inactive on the GT and Cobra.
All 94-95 Mustangs originated on the same assembly line. So, the V6, GT and Cobra share the same wiring inside the car. At a later point, they diverged and each car became a V6, GT or Cobra. This was Ford's way of saving money, combining the assembly lines. In '96, Ford split the assembly lines and only installed the wiring necessary for each car. I guess they didn't save as much money as they thought.
