Kilgore Trout said:Octane boost is worthless![]()
trailblazr81 said:I once read somewhere that 1 point on the octane booster is 1/10th of an octane point. So if you buy a bottle of octane booster that says will increas octane by 10 points, its really only bumping you up 1 octane point. Ive neve really used it nor could I tell the difference. The only thing I ever used regularlly was lead additive. I have an original 63 Mercury with 10.5 compression. I put the stuff in everytime I filled 'er up. Every once n a while I would add some 110 octane leaded fuel in it. Really waked up the motor. Racetrack around here has 100 octane but it aint cheap!!
The NOS boost works pretty good but I've tried a few others over the years [STP being one of them] that do very little.MEandmyKB said:Junk is worthless, but good octane booster works. Probably why KB says you should always keep a bottle of NOS 12007 in your car at all times. Amsoil octane boost seems to be okay too.
trinity_gt said:Based on personal experience, no. My tune seems to require something higher than 94 Sunoco to be completely detonation-free in the summer months and the only additive I've found that seems to do the trick is the NOS street-formula octane booster:
http://www.permatex.com/products/prodidx.asp?f_call=get_item&item_no=12002
I've never had any noticeable results (i.e. reduced detonation) using STP (or other similar) boosters.
RedGTvert said:You need to back off on your timing a little. There is no reason you are tuned that way for the mods you are running.
! Strangest thing I have ever seen on a car in the south!vld said:Falcon did you buy your car new? I see you are from Va, was your car built in Canada? Even though I got my car in the south she came from Il. and was built in Canada, wonder if that could have something to do with it? (Car has a block heater on it! Strangest thing I have ever seen on a car in the south!
