  • SN95 4.6L Mustang Tech
octane
  • Thread starter Thread starter mustgt88
  • Start date Start date Apr 10, 2004
1 of 2 Next Last
M
mustgt88
48
  • Apr 10, 2004
I have a new 04 gt, it was making a funky noise, took it to the dealership they asked me what octane gas I was using. I use 91 or 88, they said the car is pinging and I should be using 85 because I am in utah @ a high altitude. Hello the manual says don't go below 86 at high altitudes???? I am confuzed? What yall think?
sickstickGT03
164
Norcal and school at Portland
Apr 10, 2004
  • Apr 10, 2004
I thought if you had pinging you were supposed to use a higher octane gas?
Aaron 4.6
2,695
Georgia
Apr 10, 2004
  • Apr 10, 2004
#1. They are clearly morons.
#2. Can you even BUY gas less than 87 octane anymore?
#3. If you are pinging, you go higher octane.
Stang2382
53
Texas
Apr 10, 2004
  • Apr 10, 2004
try using full synthetic next time you change your oil. that fixed my pinging.
M
mustgt88
48
  • Apr 10, 2004
thanks, i'll try some high octane chevron and change my oil, stang2382 what kind of full synthetic did you use? Yeah and the service advisor told me that my tech guy was some expert and he has some coveted ford tool chest/box that ford only gives to the highest certified techs. lol He said I should be using 85, what a dork. My lawn mower requires 87, lol
E
el_kid_1
738
Puerto Rico
Apr 10, 2004
  • Apr 10, 2004
As far as I know, the cure for pinging is using higher octane fuel. Why the heck that jackass is telling you to use 85 octane?
twogts4us
4,188
12
79
Dunedin, FL
Apr 10, 2004
  • Apr 10, 2004
We run only 91 or better, preferably 93. No pinging problems...
M
mustgt88
48
  • Apr 11, 2004
They kept asking if I had chipped it? The car was in the shop for two days, you think they would know if I had. But no it is not chipped. But as far as altitude is concerned does higher altitude = higher octane need? In utah we have 85,88,91. 91 is as high as we go. And it is 2 bucks a gallon! That probably isn't as bad as other areas but we get paid crappy here.
wms004
2,864
Los Angeles
Apr 11, 2004
  • Apr 11, 2004
have it custom tuned.
KJ Hoppus
1,008
Elk Grove CA
Apr 11, 2004
#10
  • Apr 11, 2004
  • #10
use higher octain and try the synthetic oil, might work
KJ Hoppus
1,008
Elk Grove CA
Apr 11, 2004
#11
  • Apr 11, 2004
  • #11
BTW i use moble 1 5w30.
G
Go Heels
30
Raleigh, NC
Apr 11, 2004
#12
  • Apr 11, 2004
  • #12
Man, I had the same problem with my 2000 GT, It pings under light throttle mainly when it's a little cool outside. I took my car into the dealership and they told me to stop using gas that was higher than 87 octance..but under full throttle my car spark knocks..badly. So I use 89 octane and only drive it when it warm outside..It's my second car.
46gtsblown
278
#13
  • Apr 11, 2004
  • #13
Try cleaning the MAF and run a can of injector cleaner through it.
Dwayne
M
mustgt88
48
#14
  • Apr 11, 2004
  • #14
go heels, I think I have the same thing you do. Where do you live, carolina, and that is low altitude right? It only does it during light throttle. It is very intermittent. Sounds like a sucking, or like something thing is rubbing tinney noise? The sales manager thought it was the throw out bearing rubbing. Bad knock sensor?
G
Go Heels
30
Raleigh, NC
Apr 11, 2004
#15
  • Apr 11, 2004
  • #15
I think we do have the same problem..I live in Raleigh NC. What octane gas are you running now? I'm trying to find a shop in the area that will do a good dyno tune..finally settle it once and for all..Does your car do it at any particular temp.?
G
Go Heels
30
Raleigh, NC
Apr 11, 2004
#16
  • Apr 11, 2004
  • #16
Dwayne
The dealship did an extensive carbon cleaning..it still does it. I'm trying to find a shop that will do a good dyno tune.
M
mustgt88
48
#17
  • Apr 11, 2004
  • #17
It does it more in the cold, and when i lug it out a little - with low rpm and light throttle. What type of oil do you use goheels? full synth? The dealership said they are gonna try to get a hold of the ford regional rep, to look at the preignition pinging. They told me it could take up to 3 weeks for that. So we'll see what he will do, I am guessing probably nothing. I took the sales manager for a ride and he told me that "this is not right." It has been in the shop 3 times, the first 2 they said it was normal. The 3rd I asked to take the shop foreman for a ride myself. They finally acknowledged something was wrong. What a pain. Good thing is if i roll down the windows and hit it, i can't hear a thing!
M
mustgt88
48
#18
  • Apr 11, 2004
  • #18
91 at first, now 88, and my next tank is going to be the foreman's 85 recommendation. even tho it says specifically not to go below 86 in high altitude in the manual
G
Go Heels
30
Raleigh, NC
Apr 11, 2004
#19
  • Apr 11, 2004
  • #19
I tried 87 octane for a while and it didn't help..it only made my car spark knock under full throttle. We have same problem it sounds like to me. They even did an octane adjustment to my car which does nothing but de-tune it and it still does it. Since it only does it when it's cool outside, makes it very confusing...You can not duplicate this with engine idling..only under light load.
Let me know what you find out..
Will
01GTConv
25
Highlands Ranch, CO
Apr 11, 2004
#20
  • Apr 11, 2004
  • #20
I am in Colorado (5900 feet) and my car ran much better with then 91 octane instead of the 87.
1 of 2 Next Last
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
