m always running off of the cheap stuff when i fill up. But a bud of mine runs the highest stuff in his 66 with pretty much exact same setup as me.. is there any advantages/disadvantages for running the good stuff in ani old engine like ours?
thehueypilot said:It depends on your compression ratio and/or how much your timing is advanced. Higher octane resists detonation (spark knock) better then lower octane fuels.
67coupe351w said:WHERE do I find some of that?![]()
2.73 here today.65fastback2+2 said:look at the bottom of the gas list it'll say $2.50, now look up at the top, it'll say $2.20, $2.20 is cheaper than $2.50 thus making that the cheap stuff![]()
meanroy said:2.73 here today.
And low octane to boot.
Huh!
Carefully refraining from comment.65fastback2+2 said:hehe, im lucky to live in texas
65fastback2+2 said:$2.20 is cheaper than $2.50 thus making that the cheap stuff![]()
limey66 said:Hey guys, stop bitching about the price of your cheap gas - we pay the equivalent of seven bucks a gallon over here...
edbert said:I filled up for $2.03/gallon in my 21mpg 2005 GT this morning
Yes, it was 87, and no the 2005 GTs do NOT require 93. My 97 Cobra did but this 2005 is only down 5hp to my old Cobra (but it has 15 more ft/lbs) and it takes the cheap...errr...less expensive...gasoline.65fastback2+2 said:wow, so what was 87 octane??? like $1.90??? cuz i know you didnt put 87 in that car since it requires premium 93
At the same heat and pressure. The resistance to pre-ignition allows more heat and pressure w/o pinging, and more cylinder pressure, and more power.Max Power said:Premium fuels actually burn slower than regular 87 octane.
brianj5600 said:At the same heat and pressure. The resistance to pre-ignition allows more heat and pressure w/o pinging, and more cylinder pressure, and more power.
