  • SN95 4.6L Mustang Tech
ODBii code P0356
  • Thread starter Thread starter pkwest
  • Start date Start date Apr 18, 2007
P
pkwest
  • Apr 18, 2007
I just installed my new engine. It ran great for a short time after which it started to miss. I checked compression and it is really consistent. I changed the plugs thinking I may have damaged one while it was in the box of misc parts. It ran great for about 15 minutes then it started missing again. I thought P0356 was referring to COP for #5 so I
swapped #5 & #6. I still got the same code P0356. Which COP is F. I did get a bit sloppy with the anti seize when I installed the previous plugs. It was on
the porcelain of the plugs when I pulled them. Is anti seize a conductor? Could that have caused a COP to fail? The ford service dvd says erroneous ignition and etc related dtc's may be due to salt water intrusion into the CKP harness connector. So I cleaned the connector at the CKP sensor. No change.
4.6andSlicks
171
Central Connecticut
Apr 18, 2007
  • Apr 18, 2007
*Open coil driver circuit in harness
*Coil driver circuit shorted to ground
*Damaged coil
*Damaged PCM
*Coil driver circuit shorted to 12v
Sounds like it's on the coil side. All the moving around could have broken a wire inside the insulation. When you change a plug or move it, it makes connection for 15 seconds or so. Above is from the manual.
D
Dragstr05
643
Stafford VA
Apr 18, 2007
  • Apr 18, 2007
^^ Agreed.
If you swapped coils coils and got the same code for the same cylinder, its in the harness/connector.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 18, 2007
  • Apr 18, 2007
That code is for cylinder #6 so it's the second plug from the front on the drivers side.
After you swap it with another coil make sure you clear the codes then retest, if you did not clear the code the pcm will still have the code in there for cyl #6 coil and may have not had time to set the code for the cyl you changed it too.
Most likely the problem is the coil itself. It is very very rare to have a PCM driver fault or even a wiring fault.
If you want to check for wiring problems check for continuity from pin #1 of the PCM to pin number 2 of the connector on coil #6
Also check for power at pin #1 of the coil connector
P
pkwest
  • Apr 18, 2007
Thanks for all the suggestions. I will be getting into this in the next two days. below is a quote my ford service dvd.
" Note: On certain applications with Electronic Throttle Control (ETC), erroneous ignition and ETC related DTC's may be set due to salt water intrusion into the CKP harness connector. These DTC's are: P0320, P0351, P0356 and P2106. Thoroughly clean the connector, pack with di-electric grease and retest. If the problem returns, REPLACE the CKP sensor."
Could I have a bad CKP sensor???
Mike97gt
it doe snot
10,633
Apr 18, 2007
  • Apr 18, 2007
When a CKP sensor goes bad normally the car will not start. Plus your car does not have electronic throttle control.
What manual is that out of and what section page numbers so I can read it.
P
pkwest
  • Apr 19, 2007
Thanks again. Here is where I read it.
The ford service DVD 2002-2004 January 2005. Powertrain control / emissions diagnosis. 2004 mustang - 2004 PCED On Board Diagnostics SECTION 5: Pinpoint Tests Procedure revision date: 05/23/2004
Mike97gt
it doe snot
10,633
Apr 19, 2007
  • Apr 19, 2007
I will look into that latter since I will have to skim the entire section. But I would check that out since it's easy to take a look at the connector and clean it.
P
pkwest
  • Apr 20, 2007
It was the wire from the pcm to the coil. It was broken about 5 inches from the coil. The first time I measured it the wire had continuity. When I rechecked it last night I wiggled the wire and it showed up. It runs great now. Thank for all the help.
Mike97gt
it doe snot
10,633
Apr 20, 2007
#10
  • Apr 20, 2007
  • #10
cool glad you got it
4.6andSlicks
171
Central Connecticut
Apr 20, 2007
#11
  • Apr 20, 2007
  • #11
Great when a plan comes together. Number one on the list. Those Ford manuals do come in handy.
*Open coil drive circuit in harness
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
  • dan50
  • Jul 18, 2026
dan50
