For a couple months now, there has been a squeeling noise coming from my T-5 transmission. It does it when it's warm, cold, wet, dry whatever. The noise goes away when I depress or lightly tap on the clutch pedal though. Sounds like a classic case of a throw out bearing? The car has only 33K miles on the ticker.
Last night, I took out my Steeda Tri-Ax and put in the old shifter. Since I was taking it into the dealership for warrenty work and I didn't want it to be kicked back out.
Today, I drove the 5 miles to the dealership and no noise. Their mechanic looks at it. No noise.
I'm speechless here. For some reason I highly doubt that the shifter really made that squeeling noise. I am aware that I get some extra drivetrain vibration due to the soildness of the shifter, but what gives? Everyone I've talked to says the same thing, it's a TOB.
Any help you guys can give would be greatly appreciated! Thanks in advance!
Eric
EDIT: The idler pulley was changed out a while back ago as well for I thought it might be that.
Eric
