Off Road H Pipe Question.
Benz510
171
70
38
Oakland California
Hey all,
Is it true if i were to put on an ORH and connect everything up as i would with the OEM H Pipe that it could damage the smog pump? I was told by someone that it could because they aren't meant to be ran without cats? I scored a BBK ORH for $80 that i will probably end up putting on here and there. Just need some info on this first.
Thanks!
Does it make any kind of difference whether it be power gains or loss, etc if i left the pump on?
No real power loss. I have an o/r H pipe too and I left the smog pump on but I got a shorter serp. belt and ran it around everything else but the smog pump. I forget the length I got but it all depends on what accessories you still have (power steering, A/C, etc)
There is nothing to hook up the smog pump pipe to on an o/r h pipe. Maybe there is a way around this but I don't know it.
Isn't there a small pipe that juts off the passenger side of the H or X pipe that runs up to the smog pump, like the factory set-up? I've got a Bassani off road X pipe I will be installing in the future, to replace the catted H-pipe, and the Bassani ORX has the small pipe that juts off, to maintain the line to smog pump.
Yep. That's exactly what I'm talkingabout. The smog tube that connects the air check valve to the h pipe.
Maybe your o/r H pipe has one but my BBK offroad H pipe did NOT,
Pic below is from when I removed my stock catted H pipe to replace with a BBK o/r H pipe. No where to connect the thermactor tube to. Maybe others have it :shrug:
Well I'll be damned, out of curiosity I checked the offroad pipes from LMR and all of the o/r pipes have that tube on it. This must be new, I just bought mine from LMR last year and it has no thermactor provision on it. Learn something new every day.
Reactions: Pyrate Dave
My Bassani pipes have the same small pipe and my factory H-pipe has the same thing, that runs up to the smog pump (as far as I could see when I crawled under and took a look while the car was up on ramps. I was planning on swapping the X & H pipes, but my car has 1 more Connecticut emissions test to go through before it's exempt, and it appeared to me (and my basic wrenching skills) to be a lot of work to swap the cat'ed pipes back in next year for the test, then back out again.
Most pipes I've had over the years had the tube. I plugged it off.
If you aren't going to run the smog pump, i'd take all the stuff off and throw it in a box.
Smog pumps are notorious for locking up.
The one u have is for long tubes? Maybe that can be the difference?
I don't think so, even the current o/r H pipes on LMR that are for long tubes have the pipe. I guess I just got lucky last year when I ordered my BBK and got one without the hole. Less work for me because had I gotten one with a tube or hole I would've just welded it shut. Mines a 90', no more smog for me.
