Offset Steering Bushing
uh, the instructions say 6 o'clock, so just put them in with the holes straight down. if you did it the other way around, that would RAISE the rack and make the bump steer even worse
The holes need to be at 6 o'clock.On lowered cars,the rack needs to be close to the oil pan which kinda helps to fix the geometry,and help with the bump steer,but not totally,and that is where you will need to decide on other parts like Steeda's X2 ball joints,and bump steer kit.
