  • 1994 - 1995 Specific Tech
Oh Crap!!! I think
  • Thread starter Thread starter Guero
  • Start date Start date Oct 1, 2006
Guero
2,148
Oct 1, 2006
  • Oct 1, 2006
Well im putting new header gasket, and also doing the Tweecer again. The battery was of. So i just took the Computer of and went to my room and cleaned it. I also installed a new ignition control module. The headers are of at the time. So i pluged the computer back in, and the tweecer. Then the batery. Then i put the car on the on positoin with engine of.
The fan stays on, and the fule pump keeps priming. Why is it doing that? is it normal after taknig of the computer or puting in a new igniton control module???? Im scared, gopefully i didn't frie the Tweecer and the computer!!!!!!!!!!!!
Guero
2,148
Oct 1, 2006
  • Oct 1, 2006
OK. its the Tweecer. When its on the off position everything is ok. Now how do i stop it from doing that? when its on the position?
C
cbarr300
746
goose creek, SC
Oct 1, 2006
  • Oct 1, 2006
if I'm not mistaken, that happens when the data for ur tweecer file is corrupt. Just reflash that setting (or settings) with a new file.
I learned first hand that it's very important to save ur data for ur tunes
blwn331
69
  • Oct 2, 2006
Reflash your tweecer it is either crupt or you have no data in that bank.
WhiteDevil
2,717
San Diego
Oct 2, 2006
  • Oct 2, 2006
Did you load a file to it yet? If not then thats why. Also make sure you have the right strategy its CBAZA.
Guero
2,148
Oct 2, 2006
  • Oct 2, 2006
ok i didn't load any files into it. And yes its on CBAZA thanks for your guyes help
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 2, 2006
  • Oct 2, 2006
Since it is new .................
I'd read the pcm first.
Then load it to all 4 positions.
You have no idea what is on them at this time.
You might also have an issue of the pins on the service port and Tweecer not making good electrical connection due to the coating on the pins.
Grady
blksn955.o
3,263
st.louis mo 314
Oct 2, 2006
  • Oct 2, 2006
like grady posted, it could also still be the j3 port pins. It took me 3 times to get it cleaned up. The last time I went NUTS on it with a Q-tip of paint reducer, and paper towels along with an eraser to gently buff off the computer protection goo off the metal pins.
Mustangless
903
home
Oct 2, 2006
  • Oct 2, 2006
when I have this probelm it is because the connection is not good. If you read eec and get like crazy numbers then it probably is not a clean connection like said above. I have to put cardboard on one side between the computer and tweecer with mine
blksn955.o
3,263
st.louis mo 314
Oct 2, 2006
#10
  • Oct 2, 2006
  • #10
I did the cardboard as well, it fits soo much more square and level to the eec with that in place.
Guero
2,148
Oct 2, 2006
#11
  • Oct 2, 2006
  • #11
i loaded a quick tune and in that position it doesn't do it anymore. can it still be the connections?
blksn955.o
3,263
st.louis mo 314
Oct 2, 2006
#12
  • Oct 2, 2006
  • #12
if the fan or FP is not running non-stop then its prob. fixed. The fan/FP is like a dummy light deal IMHO used to be a fail safe to know if the eec is not working properly.
Go for a drive around the block.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 2, 2006
#13
  • Oct 2, 2006
  • #13
If the ignition is off, and you are hooked up with the laptop, the FP will run at all times. You need to have the ignition in the on position.
Scott
blwn331
69
#14
  • Oct 3, 2006
  • #14
Sounds like you got it. Take it for a drive in that position.
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
