Ohms on 5.0 Water Temp Sending Unit?
bacarruda
11
CA
What is the ohm range for the stock foxbody 302 water temp sending unit?
Looking at getting autometer gauges w/ their sending unit but will replace the stock one and want to know if it will read somewhat accurate on the stock gauges as well.
I can't run both because I already have a fan relay sending unit in the manifold, and have a thermostat housing with a port to put my gauge sending unit.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
  • Informative
Reactions: General karthief
