oil leak and PCV issues
Cobain03
996
Lexington, Ky
i noticed a burning oil smell while driving and upon inspection it was on the valve cover, mainly in the PCV area. Then we (me and dad) noticed that the sall ruber hose leading from the PCV to the hard plastic that hooks to the throttle body was almost totally collapsed. Does this mean the PCV is bad? Also, while unplugged, if you hold your finger over the PCV valve, the idle does not change.
wrong one! crap. no body in town has one of these! the tube is cracked allover from dry rot. i wenttothe local dealer to find the part, they dont even ave the PCV. has 2 options, a smooth based one you just push in, nd a screw in (type i need) but it is heated which mine is not. they cant fid the hose to save their life!
for a 2002 Gt here are the part #'s you need: Non-Heated PCV valve 2X4Z-6A666-AA and PVC hose 2L2Z-6A664-BA....if you can't get them, lmk
