That's why I'm thinking of going with a crate engine because I have no knowledge of what was done to this motor or how old anything is , just wanna do things right and not spend a fortune on paying to do all gsskets especially rear seal and oil.panYou will need to clean all that gunk off as best you can then plan on replacing timing cover, valve cover, intake gaskets and replacing the pcv valve amd the screen under it, hopefully you will not need oil pan gasket and rear main seal but likely you will,
Be prepared to replace the water pump/timing cover bolts, they are know to break.
Vacuum lines probably will need replacement too.
Welcome to the club.![]()
I've gone the wrong way before with spending money on my cars , I'm gonna try and tackle some of the gaskets myself , it's not the rear main seal most of the oil is puddle behind the water pumpRegardless of what's been done to the engine,...fixing an oil leak is gonna be cheaper than spending a fortune buying a crate engine. Any competent mechanic can fix a rear main seal leak in a day,..and tell you how healthy the engine is before you spend a dime doing that.
What's the point of asking for advice when you've made your mind up anyway?
while you are at it, take off those underdrive pulleys and that fire hazard of a fuel pressure gauge.
What do you recommend , and as for the gauge why is it a fire hazardwhile you are at it, take off those underdrive pulleys and that fire hazard of a fuel pressure gauge.
