oil suply for 2 turbos (ADHD Racing)
86mustang84
10
im about to twin turbo my ****box and just wonderin if the oil pressure sensor would be good to tap off of with like a y fitting,and how many quarts of oil should i use? uh if it helps its an 86 5.0, 2.73 rear,tremic trans,all that stuff, i just did the mass air conversion and all it did was smooth idle,no a/c no smog,electric fan, nothin is in it but 2 seat and a dash and somthins burnin in there,msd crap,stock block with girdle and vally girdle,stock ported heads and manifold,some sort of cam,spacer that did nothinegr eliminator plate,70 mm throtle and mass #19 injectors, and one more thing when i did the conversion i used a 91 computer, how do i get codes through that same connecter as befor?
You’re going to need open ports off of the oil feed log (one for each turbo and one for the pressure sensor. I originally threw a few fittings on their to extend the log out....but I always had issues with it leaking. In the end, I found the best method was to drill/tap the log for the 2 extra ports with a NPT Tap and use the appropriate NPT to -AN adaptor. In the end, it was the cheaper route to take...as those adaptors add up in price. If you are using -AN lines, you'll need a npt to -an adaptor...but those can be had for cheap. FYI, I haven't had a drop leak from that location since.
how many quarts of oil do you run for yours?and what did u do so the computer could handle the psi,piggy back system,did u use a blow through type mass air?
I use the stock (5qts) of oil. The turbo's don't use much oil at all.
As for my tune, I use a stand alone (megasquirt). As with most stand alones, it is a MAP based system which is ideal for forced induction. It also means that you don't have an expensive MAF meter to buy. You will need bigger injectors and fuel pump however.
how do i go about getting one of these?
You can buy everything from here... DIYAutoTune.com Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products
You would need either the MSI or MSII....and you have the option of either buying it pre-assembled or soldering everything up yourself (quite easy...but very time consuming).
Before you do, I highly suggest reading as much as possible here... MegaSquirt - Electronic Fuel Injection Computer by Bowling & Grippo * * ©2005
If you are still interested, you should join the forums here.... www.msefi.com
This is considered a DIY system...and does not have any true dealer support. This is where the forums are extremely helpful….as that is where the knowledgeable people (including the designers) hang out.
I’d also highly suggest searching on here and the corral for people that have built/installed them and read…read…read! :nice:
