Ok Fellas, need some ignition help
  • Thread starter Thread starter 1990Coupe
  • Start date Start date Jun 24, 2007
First Prev 2 of 2
2000xp8
SN Certified Technician
Aug 8, 2003
8,076
1,659
194
NJ
Jun 29, 2007
#21
  • Jun 29, 2007
  • #21
If you bought a chain store TFI module, take it back, they are garbage. Sometimes they are DOA, and other times they last 2 months.
In this situation, you MUST use one from ford. Seen it dozens of times at my friends shop.
1990Coupe
1,462
132
114
Toms River NJ
Jun 29, 2007
#22
  • Jun 29, 2007
  • #22
yea i bought it from autozone..
you think it could be bad? maybe ill pick up a ford one tomorrow and if its still dead ill return the ford one..
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Jun 29, 2007
#23
  • Jun 29, 2007
  • #23
Don't know if yours is dead, but it likely won't last long if it's not.
Always buy electronics/sensors from ford.
1990Coupe
1,462
132
114
Toms River NJ
Jun 29, 2007
#24
  • Jun 29, 2007
  • #24
well hopefully i can fix this tomorrow, cause im pretty fed up with it and im about ready to stick "for sale" on it. lol.
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Jun 29, 2007
#25
  • Jun 29, 2007
  • #25
When you fix your own car, this is how it sometimes goes.
After it's fixed, the bad taste you have now will be gone. Just be patient.
1990Coupe
1,462
132
114
Toms River NJ
Jun 29, 2007
#26
  • Jun 29, 2007
  • #26
2000xp8 where abouts in ocean county are you?
1990Coupe
1,462
132
114
Toms River NJ
Jun 29, 2007
#27
  • Jun 29, 2007
  • #27
Ok well i put a stock coil in thanks to FBD and nada.. Still dead.. I have 12v on the red wire and 12v on the other wire. no pulsing from the light when i test it and im starting the car. I did number 1 on the checklist and i have 0 spark from the coil. I replace the TFI sensor with an autozone unit. Could it be the PIP sensor??? im going to downs ford tomorrow to talk to the tech guy behind the parts counter and buy ANOTHER TFI sensor and whatever else he suggests..... Cause im dead in the water, and I definatly have a bad taste in my mouth after this expirence
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 29, 2007
#28
  • Jun 29, 2007
  • #28
Go back to the checklist - see item 1 D & 5 A. When you jump around and skip steps, you end up missing important clues that can help you find and fix the problem.
1990Coupe
1,462
132
114
Toms River NJ
Jun 29, 2007
#29
  • Jun 29, 2007
  • #29
I didn't think it was the pip sensor because you can smell the raw fuel as I attempt to start the car. I will go in the morning and try to find this light to test it tho. otherwise ill just replace it Thank you for all the help.. this is a demon thats killing me
1990Coupe
1,462
132
114
Toms River NJ
Jul 6, 2007
#30
  • Jul 6, 2007
  • #30
OK... borrowed a NOID light from my mechanic friend... had NO noid.... replaced the pip sensor (well just brought in the dizzy and replaced with a remanufactured unit) FIRED RIGHT UP!!!! thanks so much guys
First Prev 2 of 2
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:09 PM
2000xp8
