OK guys what do you think?
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
Complete EFI 351 w Intake buying this for a my 351w for my coupe. didnt want to go this route but then i want it in and running and cash is alittle low at the moment. So with that intake and a set of GT40P ported polished heads the block is 40 over other then that all stock, i will have ford racing 24# injectors as well as a 76MM MAF and 70MM T.B. L/T headers. Do you guys think i'll be over 300 H.P and 338TQ at the wheels or more?I dont know but hopeing also that my cobra upper will bolt to that lower? peace
john:p
Those pictures are pretty bad... Are you sure its a GT-40 lower casting? I can't say I'm familiar with that intake.
BTW, you'll be choking a 351with those parts, especially the upper with the 70mm TB. If you manage to get a hold of a 351W GT-40 lower, I'd port the hell out of it, as well as the upper, and go to a 75mm TB (at least).
I assume the goal for the new motor is to make more power than the old? If thats the case and 300/338 is the number to shoot for, I wouldnt waste the time and energy going GT40 heads and such. You wont see much more power if at all, and that seems like a lot of work for the same result.
Well i was going to go with a set of 205 AFR's with trick flow R intake,but unless i won the lottery from last night i wont be able to afford the AFR's for a while :( i want to get the 351 in this winter so it's in and running. I have stock heads for the 351 but then i also have a set on my 5.0 of the GT40P's that have work done on them. I'm pulling the engine this winter again to do some recleanning and repainting so what the hell pull the engine and install a 351! All i need for the 351 to work (if i get this stuff) is a flywheel and balancer.peace
john:p
john:p
If that is the case, I say screw that intake and look for a 351 GT-40 lower on ebay or something. That is all you would need for the swap and I bet you could find one.
Yes, it will bolt to your Cobra upper. Like I said before, a good idea would be to move to a 75mm TB and hog out the mouth of the upper, but maybe that is futile work if you are going to get a new intake eventually, anyway.
I believe there are three sources for 351 GT-40 lowers:
1. GT-40 boat motors built in the '90s. These are all but impossible to find, in my experience, unless you want to tear apart a perfectly good Hydrodyne or Nautique. I always drooled over boats equipped with those motors. Ford has since got out of the pleasure boat market.
2. FRPP aftermarket. They aren't selling them new anymore, but sometimes they show up on ebay.
3. Lightning F-150s. I bet a sly way to find one of these is by looking through the classifieds on one of the Lightning forums. These can also be found on ebay.
Ok cool i'll have to start looking on those forums and theres several boat dealers and junkyards here. peace
john:p
