ok here we go again
  • Thread starter Thread starter noslow1986
  • Start date Start date Oct 19, 2006
N
noslow1986
274
oswego Il
Oct 19, 2006
  • Oct 19, 2006
why do my headers glow red could this be my sputter and back fire at 2000 rpm. now could my whole distribtor be bad do these go bad i already changed cap and rotor. whats next to check i already dump codes code 67 and 85 i think is canister purge but i dont have emissions
stangjunkie
381
  • Oct 19, 2006
whats your timing at?? to me this sounds like a timing issue
N
noslow1986
274
oswego Il
Oct 19, 2006
  • Oct 19, 2006
yeah i advance and retared it but the hessition is still there and it back fires. no matter what i do advance or retard its still there
Sicarius428
2,085
Oct 19, 2006
  • Oct 19, 2006
What do your plugs look like. See if you are running lean. If it is either my guess is it's either a timing or fuel problem. You can also have a vacuume leak which can cause a lean condition. O2 sensors possibly but check everything else before you throw money at the situation.
Kevin
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Oct 19, 2006
  • Oct 19, 2006
A lean condition does not cause glowing headers, headers will glow for 1 reason, fuel burning in them, this can be caused by a rich condition or by the timing being too far retarded.
N
noslow1986
274
oswego Il
Oct 19, 2006
  • Oct 19, 2006
could my fuel pump be causing all my problem meaning not flowing enough at high rpms
txstang84
1,639
42
69
Tuscola, tx
Oct 19, 2006
  • Oct 19, 2006
does it smell really rich? another thing that could be causing the backfiring MAY (sometimes) be the MAF...my friend Paul had that problem when we initially did the SD to MAF swap...bad sensor, ran like poo, idled even worse, backfired, sputtered
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Oct 19, 2006
  • Oct 19, 2006
If your fuel pump wasn't flowing enough, you wouldn't have fuel burning in your headers.
rugerbp
81
  • Oct 20, 2006
got the same problem but i have 347 w/ 42 lbers w/ pro m 80 mm calibeagted to 42 adn only driveers side is glowing red hot, i think thi sis a lean issue
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 20, 2006
#10
  • Oct 20, 2006
  • #10
180 out
Happened to my friend
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
Oct 20, 2006
#11
  • Oct 20, 2006
  • #11
Headers glowing red sounds like a lean condition to me
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
