i bought the hu what else do i need i have the dash kit also... what harness do i need and should i just pay like a car toyz or someone to install it ?...help
There is a harness, but it is kind of tricky getting it hooked up, does your headunit have a high pass filter? If so you can possibily get it to work, there is a harness made for the 99 and up ford premium radios, it has three plugs in it one of which send sound to the 6x8 speakers, now the tricky part is hooking it all up, the 6x8 plug takes line level signal and the tweets take full range, so you will have to wire a interface in the wires going to the 6x8 to kick them down to line level or get an adapter to use your rcas on the deck, either way will work just takes a bit of time to figure it out, but it can be done go to a shop and get the harness it comes with a wiring diagram and then it will start to make sense let me know if i can help more Dan
