ok im gonna need some help or im going to carb
Graydon5oh
215
ARKANSAS
ok i havea86 gt5 speed i swapped and put the motor out of my 87. in it i reused the upper and lower intakes from the 86 tho. timing is set it cranks but my prob is when u give it gas it revs out at about 4500 and has no horses it also is really jumpy and has a lil popping kinda. if i dont figure this out im gonna go ahead and go to carb because this efi is driving me nutty
check the cyl 1 and 2 injector plugs to make sure you didnt cross them
"if i dont figure this out im gonna go ahead and go to carb"
No :nono: No :nono: No :nono: No! Your gonna make me cry.:nono:
:D
It does sound like the timing is out of whack. If it were me (and it has been me several times, as I seem to screw this up quite often), I would pull the dist. and #1 plug. Go through the entire timing sequence again.
I suppose it could be fuel related, but unless you made major changes to the fuel system, it is most likely just timing.
Good Luck
jason
ok i found out what it is and i am most likely gonna be critisized for it but some how i managed tocrack the lower intake giving me a pretty nice vacume leak u couldnt tell was there at idle or lower rpms
