Ok lets to this G-force vs TKO-500
G-Force or TKO-500
  • G-Force
    Votes: 14 50.0%
  • TKO-500
    Votes: 14 50.0%
  • Total voters
    28
No need to get a new shifter with the TKO's.....they come with one (at least the 500/600 do, they come with a hurst already installed).
The G-Force is a direct fit drop in, while the TKO requires more such as a DS spacer, bellhousing, and crossmember mods. So you should take into consideration if you're up to the extra labor and parts to get it installed.
When I installed my TKO-600, I also had/installed a McLeod SFI bellhousing which has bolt patterns for both a T5 and TKO, but I would've had to use a $150 adapter/spacer if I used a '94/5 specific G-force. Also, at the time the cost of a G-force was only $200-$300 cheaper than a TKO-600 and that was using a used case for the G-force.
SeventyMach1 said:
Hey, Nobody, is your G-Force pro-shifted? (as some say, "pro-cut")
When my 347 setup is complete..... I'll definitely go with a pro-shifted G-Force.
SeventyMach1 - My box is a standard synchronized engagement. I have since read about the Liberty Pro-shift and I sometimes wish I had gone that route.
