Ok so the TKO-500 is ready to put in, any hints or tips for me(pics)
WhiteDevil
2,717
San Diego
Well i got it all ready to go and i cant wait to get it in. I am putting the the bell housing on the tranny first them im putting them on the car together, cause when i put the bell on first with my T-5 it was a bitch to line everything up. I got all the stuff i should need. It looks like i am going to have to lose the bracket that has the hangers for my Xpipe but i guess that is not really a necessity. Well if you guys have done the install and have any tips or things that might make it different than just bolting in a T-5 let me kow.
Here is the TKO-500 with the bellhousing and clutch fork on it
Here is my busted T-5 in the TKOs box
And here is all the other stuff that i need to put the TKO in Fluid, 31 spline slip yoke, Driveshaft Spacer, Offset trans mount, and the handle from my Tri-ax. Anyone want to buy a Tri-ax base?
I just put mine in last week..everything was pretty easy nothin special.Let us know how it works when you put it in.what kind of clutch setup are you going with?I used a FRPP king cobra clutch and having some problems.Are you gonna use the tremec shifter?
Yeah im going to stick with the Tremec Shifter for now. with the Tri-ax handle. My roommate has one in his 98 cobra and it felt fine when i drove it. Im running a Spec 1 clutch which i have had for 400miles its a little on/off but i like it so far.
