notch22 said:
Ok, I had previously gotten my wires crossed with my first post. This cam is a not a solid flat tappet cam, so that is nothing to worry about. I talked to my dad last night to tell him to get me the part number so I will have that today. More good news, he said that it was a Crane cam so no looking for the brand either. If LSA is good then I am set......
Just to clarify the LSA is the angular spacing between the intake and exhaust lobes.
The problem with LSA's below ~110 is that this tends to create more valve overlap.
The computer can have a hard time with this.
The computer knows when it should fire each injector based on the specs of the stock cam. When you change the valve events with an after market cam, you run the risk of messing up the very precise timing of when the injector fires. What you then end up with is the injector firing while the exhaust valve is still open. Obviously this early injected fuel is sucked right out the exhaust. Only part of the fuel mixture remains in the combustion chamber, so you end up with a lean mixture in the combustion chamber.
To make things even worse for the computer, the fuel that was pulled directly out the exhaust hits the O2 sensor, effectively telling the computer that the car is running rich.
A custom tune can clear this up. If you will not be tuning the car however, it would be best to avoid the high overlap cams.
I don't remember how to calculate the overlap, but it should come up on the web somewhere
I guess what I am trying to say is that whether or not you will be happy with the cam is difficult to say.
I am curious what you find out though.
jason
