Its the type of x-pipe you have. the bbk x-pipe is very similar to the bassani. they both have a small chamber. If you run them through chambered mufflers you get that tin can sound. You have two options....change the x-pipe to a flow-tech, dr. gas or something similar with a true x-pipe design or change your flowmasters to something like a dynomax ultraflow. It will not sound right with the current set-up.
