Fox One Piece Headlights
  • Thread starter Thread starter keithwiggi02
  • Start date Start date Mar 12, 2015
  • 3
  • 4
1 of 4 Next Last
K
keithwiggi02
12
  • Mar 12, 2015
I like the look of the new one piece headlights now available for the foxbodies. I think they have a cleaner look than the stock 3-piece lights. Any thoughts?
hoopty5.0
mechanicus terribilis
7,826
6,977
214
SW Houston
Mar 12, 2015
  • Mar 12, 2015
You just opened Pandora's box there, bubba.
I don't mind some of them. But there are a lot of people here that will give up their first born before they installed those.
Reactions: elarm1 and f8tlfiveo
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 12, 2015
  • Mar 12, 2015
You shouldn't care about other peoples opinions on how something looks like 1pc vs 3pc headlights, it's your car. If you need help with install or what kind of lamps are best then that would be something I'm sure we could chime in on.
You should read the reviews on LateModel in regards to the 1pc, I believe some of those lights are not sealed very well and sometimes don't match the lines of the hood and fender as well as 3 pc lights.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 12, 2015
  • Mar 12, 2015
My experience with aftermarket headlight lenses...
Aftermarket headlight lens kit - It took about 7 days to get the lenses, 20 minutes per side to install all 3 lenses and forever to try to align them.
I drove around for several days with the driver’s side headlight scanning the upper branches of trees for squirrels, owls and UFO’s. The headlight lens had extra slack between the retaining clip and the screw head which allowed the lens to shift around. I fixed that with some small washers between the screw heads and the bottom of the mounting hole. I would recommend that you find 2 extra adjustment screws per side - they are the ones with the hex ends on the end of the screw where it sticks through the mounting plate. That may help the alignment problems, as the stock setup only allows adjustment with 2 screws, and is hard to adjust in and down at the same time.
If you bought Genuine Ford headlights, the adjustment will be easy. If you bought reproduction headlights, they will be very difficult to align properly. I bought reproduction units the first time, and my headlights could not be aligned: they would shine up in the trees and across the road. I even had all 3 screws set up as adjustment screws.
The adjustment screws are upper inside and lower outside screws. If the headlights were re-assembled properly, they will have a 5/32" hex on the screw. You can use a 1/4" ratchet with a 5/32" socket. The upper screws can be reached with the hood up, while the lower screws may require you to lie on the ground in front of the car and reach them from the bottom.
To align the headlights, find a level spot with a wall 25-30 feet away. Disconnect the driver light and align up the passenger light so that the light pattern is slightly below of the actual centerline of the headlight. This is to illuminate the right hand side of the road. Reconnect the driver light and disconnect the passenger light. The driver light should be aimed so that the light pattern on the wall is inward about 6" and slightly below the centerline of the headlight. This keeps you from blinding the oncoming cars. Disconnecting and reconnecting the headlights helps to show which headlight is shining in what direction. Reproduction headlights may shine in several directions at the same time, making it very difficult to align them if both lights are on at the same time
One Stangnetter recommends putting a fender cover over the headlight that isn't being aligned. I like his idea, it's simpler than disconnecting the lamps.
K
keithwiggi02
12
  • Mar 12, 2015
I'm beginning to think I opened Pandora by joining this group. And I don't care what other people think, I was just trying to start a conversation about the headlights. If I am going to get lectured about every post I make and why it will offend someone, I don't think I want to be a part of this group...and if it consists of people who are that anal about headlights, I know I don't.....bye!
hoopty5.0
7,826
6,977
214
SW Houston
Mar 12, 2015
  • Mar 12, 2015
That's an oxymoron.
You asked, we told. I dIdn't read any of it as a lecture.
keithwiggi02 said:
.....bye!
BYE FELICIA!
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 12, 2015
  • Mar 12, 2015
Buh Bye keitheepoo
LarsD
2,680
119
123
Texas
Mar 12, 2015
  • Mar 12, 2015
Reactions: OldManRiver, f8tlfiveo, 90lxwhite and 1 other person
hoopty5.0
7,826
6,977
214
SW Houston
Mar 12, 2015
  • Mar 12, 2015
@LarsD What have you been up to and did you ever solve the ignition gremlin?
LarsD
2,680
119
123
Texas
Mar 12, 2015
#10
  • Mar 12, 2015
  • #10
Man I hope so. Car seems to run well, but I haven't taken it on any long runs yet to see if the issue crops up again.
Reactions: hoopty5.0
OldManRiver
238
131
53
Central Wisconsin
Mar 12, 2015
#11
  • Mar 12, 2015
  • #11
TIP OF THE DAY:When some of you internet bullies answer posted questions you should state before the text,"Read this using your mothers voice",it may be more comforting for some.
Reactions: 02 281 GT
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 12, 2015
#12
  • Mar 12, 2015
  • #12
I felt we were pretty helpful to be honest. Anyways it's beer-o'thirty, the weekend is beginning for me (I work 4 tens)
OldManRiver
238
131
53
Central Wisconsin
Mar 12, 2015
#13
  • Mar 12, 2015
  • #13
Ya I thought so too.It's hard to believe someone who gets upset over something someone types on the internet can get through a single day out in the REAL world.
I will say this though,It's sometimes hard to catch someones drift ,it's almost like the reader reads it to themselves in a mean spirited way when in fact that just isn't the case.
hoopty5.0
7,826
6,977
214
SW Houston
Mar 12, 2015
#14
  • Mar 12, 2015
  • #14
Lol. I'm an internet bully?
Reactions: elarm1, Boosted92LX and TOOLOW91
Mr. Snrub
153
50
39
uh... someplace far away. (Yes, that'll do.)
Mar 12, 2015
#15
  • Mar 12, 2015
  • #15
one piece headlights are wack
/thread
Reactions: f8tlfiveo
OldManRiver
238
131
53
Central Wisconsin
Mar 12, 2015
#16
  • Mar 12, 2015
  • #16
The worst kind.The kind that hurts someone very very deeply and doesn't even know it.
Keep it up
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Mar 12, 2015
#17
  • Mar 12, 2015
  • #17
I've always wanted to use that one..
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 12, 2015
#18
  • Mar 12, 2015
  • #18
LarsD said:
Ha!
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 12, 2015
#19
  • Mar 12, 2015
  • #19
It's a trend as of late but this was on the lighter side of the dickiness.. Seems like you jumped ship even before someone said they were whack.
I had a job that worked 4 12's once. At one point I had Thurs-Sat off and back to work at 7pm Sunday. I was a little younger and a lot more single then. Made good money but it was hard to hold onto with the weekend off like that..
billbosc
122
9
28
Mar 13, 2015
#20
  • Mar 13, 2015
  • #20
I'm pretty new to the forum. And don't know much. But headlights? I have the sve one piece and they look a million time better than the 3 piece. (In my personal opinion. I just like the look a lot more) so what are the issues everyone hates them for? I'm just curious and feel free to bash me and call me names. None of that bothers me. But would like to learn the Bad things about them since I do own them now lol.
Sent from my iPhone using Tapatalk
  • 3
  • 4
1 of 4 Next Last
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
F
Black Headlight Area
  • frwgt350net
  • May 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Willybill32
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 7:42 PM
Don7Up
D
