One piece rear main conversion
  • Thread starter Thread starter 69gmachine
  • Start date Start date Jul 6, 2008
69gmachine
576
Southern Maryland
Jul 6, 2008
  • Jul 6, 2008
I posted this call for help in the Fox section, but I know there are lots of smart Ford guys over here too, so I'm posting my questions here as well:
... I need help from you late(r) model guys. I have a D1AE casting 351W block that I had converted to a one piece rear main seal. It's leaking like a son of a %$^*. I did a search in your forum and I may have caused it myself, but I can't be sure. I put a restrictor in my PCV hose between the valve and the hose to keep it from sucking oil in the intake, and that may have caused too much pressure in the crank case.
The other possibility is that the machine shop didn't bore the hole large enough and it's deforming the seal. I say that because it's impossible to install a new seal without removing the rear main cap. I've found several references on the internet that show installation to be fairly straight forward without having to do anything but tap it in place. Question 1) Can anyone tell me what the diameter of the recess in the block should be? 2) Has anyone had to drop the rear main cap to install the rear seal?
Thanks in advance for your help!
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Jul 7, 2008
  • Jul 7, 2008
You should'nt have to remove the rear main to install the seal as that would defeat the purpose. sorry dont know the specs. Take out the restictor and put in a valve cover inner plate that prevents the oil from being sucked up the hose
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
