One thing after another
  • Thread starter Thread starter anthony hill
  • Start date Start date Nov 24, 2009
A
anthony hill
74
  • Nov 24, 2009
Ok so it seems just as things get goin alright somthin elese happens! I have gotten into my car a few times lately and my throttle will stick any ideas y? theres no pattern to it it just happens when i get on it "sometimes" it did it with the stock throttle body and now with the new one so i dont think thats the problem! and idk where to go from here everytime it happens i just reach down and pull the throttle back any ideas?
thanks for the help again!!!
hill
pudman
109
tujunga,ca
Nov 24, 2009
  • Nov 24, 2009
sounds to me that you have a bind in your throttle cable or maybe the cable itself is breaking inside the housing? (don't know if that's the right word). If you unhook the cable from the tb and push down on the accelerator pedal.... does it move freely?
lancec2c30
570
Washington
Nov 24, 2009
  • Nov 24, 2009
disconnect the throttle cable and see if you can feel a snag when you move it by hand. If the throttle body isn't the problem, the cable is really the only other culprit. Unless the pedal is snagging on the carpet or something.
HISSIN50
34
129
Nov 25, 2009
  • Nov 25, 2009
Agreed with the above. WIth the cable disconnected, you can really check the throttle blade for sticking. Then run the cable back and forth in its sheath, feeling for binding or catching. Then check the carpet and/or mat under the gas pedal.
A
anthony hill
74
  • Nov 25, 2009
awesome ill give it a try thanks guys!!!
87GT40
59
virginia
Nov 25, 2009
  • Nov 25, 2009
also check the spring on the lever where it connects to the tb. i had the same prob and the spring was sticking. a litte wd-40 and no probs since.
M
MeanVertGT
11
New Jersey
Nov 25, 2009
  • Nov 25, 2009
Sounds like the cable is Binding
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,231
2,929
224
Vass, NC
Nov 26, 2009
  • Nov 26, 2009
Anthony, I sympathize with you about it being one thing after another. And man, all I can say is that's the way it is with old cars. Hopefully, you can deal with each situation as it comes up so that there is never more than one issue wrong with the car. Dealing with one situation at a time is tedious work, but don't let the issues out run you, because dealing with several problems at once can feel overwhelming.
Unfortunately, the only way to get away from it is by purchasing a new reliable vehicle, which I am not willing to do. New cars are way too expensive and depreciate too fast.
Chris
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
