Only gas gauge works and lights
Jrp97gt
Jesup georgia
Just got a 97gt . Only gas gauge works. Took cluster out and one ribbon on the right plug was out of alignment, fix it and now i have cluster lights but still no other gauge works but fuel gauge. Speedo gear is broke so i know odometer wont work but is my cluster bad? No signs of any burn marks and i replaced the fuse
Fortunately, the 97 cluster is literally just a set of individually wired gauges (along the printed circuit), unlike the CAN bus controlled one in the 99-04.
I don't have the wiring diagram in front of me, but those should be fairly simple to trace back. Each gauge should have a B+ (Battery+) and G pin, in addition to a signal pin for coolant, oil pressure, and tach.
If most of them aren't working, I would suspect an issue with the printed circuit or wiring. Make sure they all have power to start. If they do, some more detailed diagnosis is required.
